83 toyota trani question
jeswade
Active Member
sometimes when i try to shift into gear it wont go.. and sometimes when i down shift it wont go into gear also ... I have to pop the clutch pedal a couple times then it make a banging sound then i can shift into gear..Whats up with that??? is it the clutch???? trani???? Help !!!!
I have had issues with my transmission not shifting correctly when the bushing on the end of the shift tower goes bad. Might try that too. :awesomework:
I've deleted the bs.....it's obvious this guy's got an issue.
Jeswade, need more info....does the clutch pedal 'feel' normal, or is it mushy?; does it grind when going into another gear? Is the shift pattern sloppy???
Knowing things like these could and would go a long way toward helping you out....:awesomework:
yes the clutch pedal feels the same as always...it does grind when shifting gears..yes the shift patteren is sloppy.. im sure it need a compleate rebuild..
Sorry if this is a dumb question, but is it a 5sp. or 4sp.? I have an extra 5sp at my house that came out of a good working 90's 2wd pickup.:awesomework:
Edit:
Is your truck 2wd or 4wd????:corn:
