84 toyota 22r charging problem
This can be done quicker than troubleshooting the old problem.
The 1 wire is cheaper and easier to find.
I dont understand why it took this long for someone to suggest it.
Toyota charging systems SUCK.
plan on it. would like to fix the problem first
speaking of electrical problems in toyotas maybe someone will know the answer to this one as well i am not too worried about it but i always like answers that explain ****.......
82 toyota pickup 22r i checked power everywhere everything is what it should maybe even alittle better # wise but not out of proper range... anyway my charge light is always on.....
a person told me once that sometimes when the alt is changed and adds a little more juice then the system is used to the light comes on but i am not an electrician so im not sure what causes this
My 81 did the same thing---ended up being a bad solder joint in the charge relay---re-soldered it, and light's out!:awesomework:
