Sold/Expired 88 TOYOTA CRAWLER
chevyman6920
Member
dayton,tn
1988 toyota cab truck that is fuel injected.The truck is sittin on 35 pro comp x-terrain tires.Three of the tires are in really good shape with about 90%tread and one tire has bout 50%.The truck has been converted to straight axle welded front and rear.The truck has all after market suspension from trail gear.Drive shafts were extended and welded by hudlows.kc lights.The straight axle conversion also came from trail gear.It also has 14" travel bilstein shocks,has alot of flex.Transfer case has been geared 4-1.This truck will really crawl.This truck has been all over lewis chapel mtn and has went up some of the roughest out there.This truck has been up the Moab,the quarrie hill,and believe me or not it went up the waterfall last year before it got to rough for a cab truck without a cage which will be in progress this winter.If you dont believe me just ask around or come out and will prove it.$2800.423)883-7514 OR 423)260-7359.THANKS
[attachment deleted by admin]
