doubleud
All parts located in Tuscaloosa, Al. All prices negotiable
Corporate 10 bolt front axle 8 lug 3.73:1 gears welded open carrier, broken short side axleshaft, will need shaft, u joint and stub axle. $200.00
Corporate 14 bolt F rear, 4.10:1 gears, detroit carrier, no differential action, i have not split the carrier to see if its repairable or not. SOLD
Dana 30 and 35 from 1993 ZJ. The spring perches have been cut off both axles. This is a ZJ front so it's the low pinion version with CV axleshafts $75.00 for both
NP 203 out of a 1979 K5 Blazer, it has a part time conversion kit installed, so no center Differential. $75.00
305 "HO" Sbc out of 1985 Monte Carlo. Was running fine when removed, Removed it to install a stroker motor. It has been sitting in my shop for over a year with no valve covers though so it probably needs the oil pan removed to ensure there are no critters inside, it has been kept dry. $100.00 sale pending
All prices negotiable, call or text (205) 534- five 420. Please leave a message if you call, I work Midnight shift.
