Jduck
SOLD!!
6.0 lq4. Texas speed cam, push rods and pac valve springs, new oil pump, new water pump
-th350 trans. Ptc converter, tci 36 element sprag with hardened race, upgraded clutches and steels, extra capacity derale pan, lokar locking dipstick
-Atlas 3.8
-1350 ujoints, 1/4" wall driveshafts
-Chevy Dana 60 front. 4.56 gears, Grizzly locker, superior shafts, ctm ujoints, trail gear double ended steering ram, high steer arm tied into stock steering arm.
-14 bolt rear, 4.56 gears, welded carrier, Yukon chromoly shafts, disk brakes
-43 sx stickies on 17" racelines beadlocks
-headers, all v band collectors, 3" borla xr-1 race muffler
-Dodge 2500 master cylinder, brakes work great. Adjustable proportioning valve for rear brakes
-Aluminum radiator with Taurus fan
-Derale steering and trans coolers with built in fans. Trans has a second cooler in front of radiator
-Red top optima
-All fuel and trans plumbing are -6 an hose
-10gal fuel cell, walboro 255 pump
-Corbeau Baja xp front seats, 36" bench in back
-prp harnesses in front, padded shoulders. Rear bench only has lap belts
-1.25 heim joints, 1/4" wall Dom links in rear
-mix of heims/Johnny joints in front
-art Carr trans shifter
-autometer gauges
-summit mojave heater under dash
-amp mounted behind dash, 6.5 alpine speakers in dash
-quick car fused switch panel in dash
-king 2.5 coilovers on front, King 2.0 coilovers on back
-rubber bumpstops front and rear
-all Dom tube cage/backhalf aluminum roof
-9k winch with rope
$22,000 located in Watkinsville Ga
https://vimeo.com/187547451
-Atlas 3.8
-Red top optima
-autometer gauges
-9k winch with rope
