95 yj ls one tons(sold please delete)
97jerrod
Member
95 yj wrangler with clean and clear title
Ls 5.3 from 2001 chevy 1500
Superior radiator with electric fan
150 tunes harness and ecm tune
Regulated return electric fuel system with 15 gal alum tank
All an aluminum fittings
Shorty headers
Optima battery
12 volt guy switch panel
Auto meter gauges, speedo dont work needs cable and tach dont read right sience motor swap
Front dana 60
Btf high steer arms
Hydro assist steering
4:11 gears welded diff
New hd leaf springs
Motobilt diff cover
Rear 14 bolt
Trussed and 4 linked
Fox air shocks
Disc brakes
Th400 tranny just gone through
Tci torque converter
Reverse manual valve body with engine brake
Np203 transfer case
Twin stick shifters
Full roll cage built from 1-5/8 dom tube, most was tig welded
Harness and seat mounts attached to cage
Corbeau seats
Smittybuilt xrc10 winch
Quick release steering wheel
Copper nickle brake lines
37" trexus mts on 15" weld beadlock wheels
Tranny mount is removeable made out of 1-3/4 dom
Frame has been repaired and plated in all the common areas, steering box section was just replaced.
Only bad spots still on frame are right in front of rear bumper
Runs great, no issues ready to go, comes with windshield and steel half doors
Located in grove city ohio
614-361-0154
$8000 obo
Yes it is. You need to call. He hardly ever checks in here. He's a good dude to deal with too.
