Gadametz
I have a 1997 Jeep TJ with an automatic and 4cyl
It has under 95k miles
12" Radflo coilovers front and rear
17" TR beadlocks and 39.5 iroks 60% tread
Front Axle-79 Ford Dana 44 hd 8 lug
brand new ball joints
new brakes
5.13 gears
arb locker and compresser
warn hubs
Spicer lifetime ujoints and shafts
3-link on heims and a johnny joint at the lower end of the trac bar
hydro assist and 1 ton tie rod
Rear Axle- 79 Ford dana 60
spool
Stock 1-ton shafts
truss for 4 link
5.13 yukon gears fresh bearings and oil
double triangulated 4 link
Driveshafts-
1310 at t case
1350 at axle rear and 1330 front
incredibly beefy (4cyl wont break it)
Armor-
Poison spyder fenders
poison spyder frame sliders
Poison spyder on rear quarters
The cage is custom made to look like a poison spyder cage but they made it stronger
Full belly skid that that connects the upper links at a lower point to help with the angle
heims are boxed in by 1/4" plate
Seating-
both front seats are nice racing seats with 4pt harnesses
rear seat is stock but has harnesses bolted through the floor
Miscellaneous-
bright led rock lights and led bar on front
steel bumper on the front with a 9500lb winch (will pull the jeep up a tree)
cb radio
2500 MC
grab bar integrated through the cage for the rear passengers
tube doors
RCI cell
Currently Tagged and Insured
I drive it around town often
Heat and A/C work
82" wide and 112" wb (fits perfectly on a trailer with 83" wide fenders)
In the last 2 weeks-
New ball joints
Camshaft position sensor
distributer
Master Cylinder
Rear seals
front brake pads
Headlight switch (all lights work)
wheel bearings
diff oil and tranny fluid
complete tune up
front driver hub is fairly new
4Lo has plenty of power to pull it up anything but not enough to break parts
These pictures are shitty because my phone camera is broken
Text For better pictures or more info!
Located in Fayetteville Ar
501-918-8288
10k
new brakes
5.13 gears
warn hubs
spool
Stock 1-ton shafts
truss for 4 link
Driveshafts-
1310 at t case
Armor-
Seating-
Miscellaneous-
cb radio
2500 MC
tube doors
RCI cell
Heat and A/C work
New ball joints
distributer
Master Cylinder
Rear seals
front brake pads
wheel bearings
complete tune up
501-918-8288
10k
