Sold/Expired 98 TJ Dialed in and ready to get IT! SOLD!
Rockjock
Atlanta, GA
SOLD!
1998 TJ Sport
5.2 Magnum V8 (300+ HP) FAST 52mm Throttle body, Doug Thorley headers, Pro Power ignition, etc, etc
NV3550 5-speed
Atlas II 4.3 with HD 32 spline output.
KMC beadlocks Aluminum with Aluminum rings + 40" Maxxis Treps sticky comp compound
Front Axle Dana 60 HP
-Detroit Locker
-5.38 gears
-Yukon chromoly shafts inner/outer
-Bobby Long 300M u-joints and Spicer HD joints
-Forged 1350 yoke
-PSC hydro assist
-Teraflex drive flanges
-DOM high steer arms w/ QA-1 rod ends
-BTF high steer arms
-BTF front 4 link truss system
-BTF Diff cover
Rear Axle Dana 60
-ARB 35 spline
-Forged 1350 yoke
-BTF rear 4-link truss system
-BTF diff cover
-Disc brakes
Suspension:
-TeraFlex LCG max system dual-triangulated (moddified for stretch) ride height is same a TJ with 4" springs (nice and low)
-108 WB
-2.0" X .250" Wall DOM upper and lower control arms
-BTF 4-link front truss
-BTF 4-link rear truss
-1" BL
-Currie Ent. AntiRock front swaybar
Fox Coilovers 2.5 remote reservior upper/lower coils and tinder coils all 4 corners
Fox 2.0 Air Bumps
CNC cutting brake for rear.
Tom Woods front Rock-N-Roll 1350 CV driveshaft
Carolina Driveline Chromoly 1350 rear CV driveshaft
TeraFlex Belly Up Flat skid, varoius other armor
Warn HS9500 winch
TNT Phantom front fenders (painted to match)
Poison Spyder rear corner comp cut protection (painted to match)
Cutom full cage with frame tie ins and 5 point harness mounts
Hunsacker racing seats (reclining)
Kilby On-Board-Air system
RCI 15 gallon fuel cell
Bottom line this Jeep is dialed in. Get in, wheel the piss out of it, wash and repeat. Drives down the road just fine too. Took it to Jeep Beach last year and drove it around Dayton, FL with no problems. There is enough room to put the back seat in aswell.
Clean ***le in hand was tagged here in GA.
$16k. Come get it before I part it out.
Re: 98 TJ Dialed in and ready to get IT!
This Jeep flat out gets it done guys. :****: Good luck with the sale Josh. :dblthumb:
Thanks man. It hasn't let me down yet just gotta keep that shine out my hands... laughing1
Part out list and prices:
1998 TJ Sport, Clean ***le 81K on odometer ( I have another stock TJ frame too) $2000
5.2 Magnum V8 (330 HP) FAST 52mm Throttle body, Doug Thorley headers, Pro Power ignition, $2500
motor mounts, radiator, engine computer and wiring, fan, v8 throttle cable, spare factory fan/clutch, various spare parts
NV3550 5-speed $650
Selling a NP231 Tera Lo 4:1 and HD Advance Adapters SYE with 3K miles (keeping Atlas) $1200
KMC beadlocks with 40" Maxxis Treps sticky comp compound $2500
-Detroit Locker
5.38 gears, with master install
35 Spline chromoly shafts inner/outer
Forged 1350 yoke
PSC hydro assist (TJ Extreme Hydro assist kit)
Teraflex drive flanges 35 spline
Chromoly heat treated high steer arms w/ 7/8" QA-1 rod ends 3/4" hardware, Genright
BTF Diff cover, truss, CA mounts
Includes a spare set of unused Yukon 35 spline outer Stubs and 300M U-joints machined for 45 degree turning.
$3500
Rear Axle Dana 60
-ARB 35 spline
-Forged 1350 yoke
5.38 gears, mater install
BTF diff cover, truss, CA mounts
$1600
Suspension:
Teraflex LCG max system dual-triangulated (modified for stretch) $1000
-108 WB
-1" BL $75
Fox Coilovers 2.5 remote reservoir coilover, Eibach upper/lower coils, and tinder coils w/ triple rate sliders all 4 corners $1650
Fox 2.0 Air Bumps $250
Tom Woods front Rock-N-Roll 1350 CV driveshaft $200
Carolina Driveline Chromoly 1350 rear CV driveshaft $200
TeraFlex Belly Up Flat skid, various other armor
TNT Phantom front fenders (painted to match) $375
Poison Spyder rear corner comp cut protection w/ metal fender flares (not show) (painted to match) $300
Cutom full cage with frame tie ins and 5 point harness mounts Poison Spyder Customs $750
Hunsacker racing seats (reclining) $300
Kilby On-Board-Air system $300
RCI 15 gallon fuel cell $250
CNC Cutting brake $100
The one thing I knew the Durangler had that I wanted , aint in the part out. Trade you a 241OR and some cash for the Atlas. :dblthumb:
Bump for a rig that will getter done in style.
Wheres the pics , im definatly interested !
Sorry , i looked at it first on the computer at work and web sense blocked the pics. Im at home on mine and can see the pics now. Is that a king pin 60 front end ?
Yes, the front axle is a King Pin Dana 60 and I haven't had a single problem out of it. Just replied to your PM too.
You can see the Jeep in action at the 2:05 minute mark; RDB Shamrock Run 2012.
[flash=640,360]http://www.youtube.com/v/mC6UJRArFuE&rel=0&hl=en[/flash]
Thanks for the video time Cole. :dblthumb:
Thanks.
But I'm not interest in any trades at this time. I'm actually in the process of building another TJ right now just trying to thin the herd a little.
offer still stands, just let me know. 8)
I might be interested in both drive shafts. What is the dimension on them?
Is this still for sale?? No replies.
