Sold/Expired AAM 11.5" Housing
pjprice
Huntsville, AL
Pulled out of a 2008 Duramax. Gears are crap. Housing is all that's good. Have 2 factory shafts that I'll let go with it. $175 $125
256-783-2854
Re: 14 Bolt Housing
Re: 14 Bolt Housing
wellshilloffroad said:
Looks like an AAM 11.5 rear end. Is the carrier good?
Housing and shafts are all that I know is good. Carrier is probably alright but I haven't pulled it out and inspected it or anything.
Re: 14 Bolt Housing
jordan7118 said:
Yeah, that's not a 14-bolt.
I am aware it's an AAM 11.5" but I was under the impression that it is still considered a 14 bolt. Maybe not your traditional 14-bolt but still considered a 14 bolt. From what I've heard this is actually thicker and heavier than a traditional 14 bolt but still runs the same guts. Feel free to correct me if I'm wrong. Without being a **** of course because I did state in the post what it came out of. Everything I've read this is considered an AAM 11.5" 14 Bolt.
Re: 14 Bolt Housing
It may have 14 bolts on the cover, but that's about all it shares in common with the traditional "14BFF" Corporate rear 10.5" axle. What you have is a stout axle, but not in the 14-bolt family.
What spline count on axleshafts? Issue with this axle is aftermarket support and limited options for lockers and possibly even gears.
Re: 14 Bolt Housing
30 spline. I'm not sure about gears but I know locker wise there are numerous options. Including ARB, Eaton, Detroit, as well as Yukon. But I appreciate the input buddy!
Re: 14 Bolt Housing
Believe there were two different spline counts offered, and one was the 30-spline that's same as 14BFF.
GLWS
