Airshocks
84YotaBoy
City & State/Province
Maple Valley WA
who around covington can fill them with nitrogen also what type of oil does everybody use my rig weights maybe 2500 lbs and i want it to sidehill decent thanks
im still looking up how much oil works for a lighter rig for less body roll but once i fill them up i just need them filled...i assume once there is enough nitrogen i mount them up and slowly let out air until ride height
im new to airshocks how do you get the ride height then
At very least you're gonna need a gauge. There is a reason that most guys with air shocks buy a fill kit.
Setting ride height after filling is gonna take some guess work. Mine always settle 1-2" after moving around a bit. 215# front and 175# rear would get me sitting with around 6.5-8" of shaft showing. Drive it around the block and it would be down to 6" where I wanted it. Just letting "air" out of your shocks is gonna get you nowhere near where you want them and you'll probably end up with some kind of lean.
As far a side hilling goes. There is far more to that that just shock air. Link design has as much to do with side hilling as shock tuning.
2500# is super crazy light, what is your rig? I'd bet your heavier than you think.
This is just the tip of the ice berg.
its a gutted out zook on toy axles and 37s
My gutted zuk was almost 3k.
Chop that factory frame out of there its real heavy. You have a bunch more factory weight left than I did. Dash, frame, etc.
I stand by my heavier than you think comment.
Crazybluerider, you have 1 ton axles and he has Toyotas? If so there is a big difference in weight between the 2.
44's but yeah a little heavier for sure. But I also had a hand built frame that weighed about half of the stock one along with interior completely stripped and floor removed in favor of thin sheet metal.
Enough said, thought you had Tons.
