paradisepwoffrd
you could also mount a gopro under there while you wheel to see what's going on. I would put some fresh paint or something to coat the parts then take it out to verify the damage reoccurring.
A friend is having a similar issue but it is where the driveshaft comes out of the carrier bearing. His is only when the pinion side is full droop and opposite side stuffed. They are DOM links and its turning down the driveshaft weld but not damaging the link. He has 2" or so clearance at ride height.
