Want to set up an auto for offroad only and would like it to have some engine braking.Probably a turbo 350 or 700R4.Any input would be great.:awesomework
What about stall speeds?Pros and cons of 700R4 vs turbo 350 vs turbo 400
stall speed depends on converter design and engine torque.
Whats a good combo for a 99 5.7 vortec
one that works
I would go with the T-350 out of the two you mentioned, tho a 400 would be my top choice. And on the full manual thing, Trans Go makes what they call a stage 3 shift kit that makes the trans a full manual shift with compression braking for about 100 bucks. I have had this kit installed in three of my autos that I have run and it works flawless. Now if you want a reverse pattern you will nees to get a different valvebody to achieve it. If you want a standard shift get the Trans-Go kit as it is about the 1/3 of the price of a manual valve body. Also dont skimp on a shifter, get the Art Carr as they are the best IMO. Good luck.
one that works
I have some posts in this thread explaining a little bit about torque converters.
http://www.nw-wheelers.com/forum/showthread.php?t=3915&highlight=Auto+Manual
You need more info than "99 5.7 vortec" you need engine mods, trans and its mods, transfer case gear ratio, axle ratio, tire size, vehicle weight, and inteded use. some shops can build you a custom converter for your application or recommend a off the shelf unit.
