Sold/Expired Barnes 4WD Jeep JK Rear Track Bar Bracket
Barnes 4wd
Barnes 4WD Jeep JK Rear Track Bar Bracket​
This is our rear Jeep JK Rear Track Bar Bracket, it is designed for lifted and stock Jeep JK’s, the stock rear Jeep JK track bar mount is inadequate, flimsy, and prone to failure, our track bar bracket addresses these shortcomings and gives you more mounting options. Our bracket will get your axle back in the center of your JK, and correct geometry problems that are a result of suspension lifts. This bracket has 4 mounting options from stock all the way up to 3” above stock in 1” increments, so you have numerous options that will correspond with most lifts, and future suspension upgrades. Installation is easy; simply locate the bracket an 1/8” from the edge of the factory bump stop pad, and perpendicular to the top face of the factory bump stop pad, and weld in place. Our Jeep JK rear track bar bracket is manufactured in the U.S.A. from our Ultra 100 steel that has a yield strength of 100,000 pounds, so you can take confidence in knowing that you have the strongest bracket available that will last a lifetime. It is compatible with all year model 2 door and 4 door Jeep JK’s, it features the factory 1 5/8” mounting width and the factory size 14mm bolt hole.
