Best way to cut 1" thick steel
underoath4177
Active Member
I've got some 1" thick steel i was going to use to make d-ring recovery points out of, like the ones from tmr that go all the way through the bumper and welded on both sides. I got a quote to get them water jetted out and they want $125. Seeing As how i can buy them for $40/pair, that ain't happening. So what would be the most accurate way to cut them out myself?
Sent from my SPH-L710 using Tapatalk
Re: Re: Re: Best way to cut 1" thick steel
underoath4177 said:
I already have the steel.
I've cut them with a torch or cut them out with a portaband in the past, then cleaned them with a grinder.
Is it plate steel (like a big sheet) or flat stock?
Barnes sells 3/4" ones for $17/pair http://www.barnes4wd.com/Bumper-Clevis-Pair_p_279.html
Torch with #2 tip so it forces you to cut slow then cleanup with a grinder.
Not as bad as you think if your good with a torch
Re: Re: Re: Re: Re: Best way to cut 1" thick steel
Plate steel. Awesome thanks, I'll check them out.
Sometimes it is hard for us to admit it is cheaper and easier to just buy certain things!
afirover said:
Alot of times with plasma you dont get a good cut when that thick even if the machine is rated for it. I may be old school by using a torch for anything over 1/2 if I want it to look good
Have cut 1" steel a lot just use a large 4-5 tip and crank up the oxy pressure and go slow, smooth them up with a 4" sanding disk
I normally use this torch
& then clean it up in the mill if it needs it.
