"Blacked Out"
jsg1113
Cincinnati, OH
Here are a few pics of my first build. I started this build around Aug/Sept 2013. Finished it about 6 months ago
EXTERIOR
2005 Colorado/Canyon extended cab
1 3/4 .120 DOM on cage, .188 on lower frame rail and impact areas
4 linked front and rear on Fox air shocks
1 1/4 heims on lowers and 3/4 heims on uppers
DRIVETRAIN
2006 LS 6.0
Built th350 - TCI internals, full rev manual valve body, art carr shifter
Atlas II case - 3.8:1 HD outputs 1350 yokes
.188 chromo driveshafts - Carolina Driveline
AXLES
Chevy Dana 60 front
Yukon chromo axles
5.38 gears
Yukon grizzly locker
full hydro steering - PSC
undercover fab diff cover
14 bolt rear w/ disc brakes
5.38 gears
welded carrier
undercover fab shaved diff cover
OTHERS
TWF double beadlocks w/ inner and outer reinforcement rings
43" Super Swamper SX's
31x19 aluminum radiator
RCI fuel cell
TWF 20" lightbar
Re: "Blacked Out"
Here is the cab when I picked it up
Re: "Blacked Out"
2001 4.3 w/ cam
built th350 full reverse man valve body TCI internals
Atlas II t case 3.8:1
Re: "Blacked Out"
getting everything in place and frame rails built
Re: "Blacked Out"
frame finished and cab removed for finish weld
Re: "Blacked Out"
winch mounts made, frame primed and painted, started on console
Re: "Blacked Out"
console finished, cab removed
cab undercoated
interior I used spray in bedliner
cab primed
Re: "Blacked Out"
cab painted
extended cab doors welded shut, bondo and repainted
Re: "Blacked Out"
cab mounted
linked front and rear roller at this point
Re: "Blacked Out"
heres some interior pics.... 12'' sub, amp, battery mounted, small bench seat made in the rear
console and dash almost finished up
ecm mounted
Re: "Blacked Out"
started caging the back first
Re: "Blacked Out"
rear finished
radiator and catch can mounted, fuel cell mounted
Re: "Blacked Out"
shock hoops made
fenders and hood cut and narrowed
grille mounted
Re: "Blacked Out"
TWF light bar mounted behind the grille
Orbital mounted
started caging the rest
Re: "Blacked Out"
more pics of cage
Re: "Blacked Out"
finished cage, welded, primed and painted
this is basically the finished product, just before the first pic I posted
