Way back in 2007 I decided to build a Bluetorch 4 seat Buggy, It took me a year to finish the original build. Over the years I have grown tired of jumping in and out of a buggy, I had also fell in love with the rolled tube roofs Wide Open Designs was building so why not cut the roof off and add doors.
A little about my rig: Bluetorch 4 seat Fusion chassis, 114 wb, 24" belly height, High Pinion 60 Front, 4340 axle shafts, CTM joints, Detroit locker, 4.56 gears, Stak 2 speed, Shaved 14 bolt with Detroit locker, LS1 with custom ground Comp Cam, PRC Stage 2.5 LS6 heads, Melling High Volume Oil Pump, Canton trap door oil pan, built TH-350 trans, Hughes Stall Converter,Edelbrock headers Saw Coil Overs, Fox nitrogen bump stops, Beadlock Specialties wheels, 40" Maxxis Sticky Treps, and a Bunch More Stuff
Chassis setting in my small garage back in 2007
2007 Build Photos
At my friend JT's shop in 2007 he set up the suspension, added the trusses, and basically turned it into a roller
Fast Fwd Several Months in 2007
Had all the floor pans and interior sheet metal Rhino lined.
Wiring
Lets Fast Forward to Dec. 2013
I will post more tomorrow.
2007 Build Photos
Wiring
! Nice work man! :****:
