Boardbysled's Budget Buggy Build
boardbysled
Tree Nerd.
City & State/Province
NW Oregon
I recently started a new project and figured it was getting far enough along to share.
This build will be a budget build reusing many parts from my old rig ( The Pathy). (which is currently still together and I am still wheeling it for the time being.
New rig will be lots of tube with just mostly the firewall and windshield frame left from the stock rig. Frame will be cutoff in front of the motor mounts and behind the seats.
FB_IMG_1465184324899_zpsbltkvjvi.jpg~original
Couple reasons for starting fresh versus just building my current rig:
-Pathy's motor is on deaths doorstep
-Pathy has a 5 speed versus an auto in the new rig
-Fresh frame (Pathy's frame has a few patch jobs on it
Parts I plan to use off the Pathy include:
-Waggy D44 Front axle (4.56's, yukon chromos & super joints, lock-right)
-NWF TX-10/D300 doubler kit & JB Fab twinsticks
-Rear H233b 4.63 third member w/lock-right
and thats about all haha.
Here is the 'new' project. Stock 1992 Pathfinder VG30E and a auto trans.
20160306_123753_zpsyoiqe7lz.jpg~original
Some new parts,
EMPI Wide vinyl suspension seats from Jeep Swag
2.5"x16" FOA Coilover shocks with reservoirs
Speedway steering wheel and quick disconnect
20160306_124041_zps6mjpfuxg.jpg~original
Pulled the housing and stripped the brackets off it and shaved the drain plug
20160409_170218_zpsedxrbsi9.jpg~original
Started building an axle truss
20160626_202536_zpskqsslc0m.jpg~original
20160626_202547_zpsedmxmkgj.jpg~original
20160703_150152_zpsdhvnter3.jpg~original
20160703_150208_zpsnnbflkf1.jpg~original
20160716_133657_zps6xzworpy.jpg~original
Fabb'd up the rear 4 link, double triangulated with decent numbers according to the 4link calculator. Barnes 4wd brackets and heim joints. PVC links for now.:D
20160717_173948_zpshufws5o4.jpg~original
20160717_173958_zpsgxgkvwal.jpg~original
20160717_191035_zpspzbxqjgj.jpg~original
Started on the tube work! Most of the tube is 1.75"x.120" DOM with some 1.75"x.120" HREW where it won't make contact with rock, along with some 1.5"x.120" HREW mixed in.
Hole-sawed a hole in the frame.
20160724_145829_zps8drsnnpk.jpg~original
Cut it off in the center of the hole so the tube mates up well.
20160724_153118_zps2bnhcyha.jpg~original
20160724_165807_zpshdljxqfu.jpg~original
Broke the follower die getting the bends too close together.:mad3:
20160724_204425_zpsstomxxun.jpg~original
New style follower die from JD2.
20160821_150204_zpshv6nzdzp.jpg~original
HF notcher setup. (Drill died today after about 18 notches)
20160724_212754_zpsvnfynmqi.jpg~original
Notch fresh from the HF setup, just needs a little flap wheel work.
20160724_212745_zpsviuiyvgg.jpg~original
Matching rear 'framerail'
20160828_144304_zpssl3pjs1z.jpg~original
Crossbar in the rear (hopefully setup for a rear swaybar in the future)
20160828_151809_zpsmyanobfk.jpg~original
Cut the rocker panel off to make room for the slider bar.
20160828_182940_zpsg75qlnim.jpg~original
Slider bar and b-pillar mocked up.
20160903_172715_zpsxtcj2c7g.jpg~original
Rear belt-line bar mocked up
20160903_211848_zpsl3kzyxso.jpg~original
Rear seatbar mocked in
20160905_201933_zps9ivyk29s.jpg~original
Bend in the front seatbar to clear the transmission shifter cable
20160917_152358_zps4xhpkrkb.jpg~original
As an Amazon Associate we earn from qualifying purchases. Product prices and availability are accurate as of the date/time indicated and are subject to change.
And now we are caught up to today:
Started on the roof-line bar.
20160918_143037_zpsdnggdq0m.jpg~original
Roof-line bar & B-pillar connected. Next step will be to bend the roof-line bar down to meet the belt-line bar at where the rear shocks will mount in the future to make a node.
20160918_195623_zps16resp5l.jpg~original
Thanks for sharin, fun to see people's progress on there builds with the tubing and creativity , will be following your progress
Worked on it a bit more today. Decided that before I got much further, that I should redo the rocker bars. Moved them up about 6". Made sure to add frame plates.
20160925_165012_zpsr68zpgi2.jpg~original
20160925_165019_zps9c29uefq.jpg~original
Was able to work on it a bit this weekend,
Shortened the rear framerails
20161002_151918_zpsevujjgh6.jpg~original
B-pillars and rear belt-line bar in:
20161002_154827_zps3upz4mgb.jpg~original
Notching the A-pillar
20161002_161829_zpsrlx62mrm.jpg~original
Roofline bar in, just need to cut and turn it and notch the C-Pillar.
20161002_171342_zps3eheeg19.jpg~original
Didn't get a chance to work on it a whole lot this weekend, but got a little bit done.
Got the A-pillar/roofline/C-pillar bar in. All one piece, 3 bends, with 2 offsets.
20161009_143527_zpsk5qzuk3z.jpg~original
No pictures, but worked on the seat mounts some. Being 6'4" and mostly torso is making it a little challenging.
After about 4 different variations, I was able to get the seat mounts in. I'm 6'4" 300lbs so it was hard to get them low enough without having to raise the roofline a bunch. They are sat as low as they can go in the chassis, but should work good.
20161015_200512_zps0ijxoa2v.jpg~original
Got the passenger side roofline bar bent up. Had to cut and sleeve this one as one of my offsets was a few degrees off.
20161016_151110_zps9gcadc1u.jpg~original
20161016_151127_zps7fz2l2lg.jpg~original
20161016_151140_zpsfvfcbgrg.jpg~original
20161016_151147_zpsue0as8av.jpg~original
Did a timelapse of bending up the roofline bar:
https://youtu.be/K8xVM1xtaIE
Got one of the roof bars in along with the harness bar. Also got some of the triangulation bars for the B-pillar in. I plan on ditching the normal headrests and making some that attach to the diagonal bars.
20161016_183436_zpstca6h0gc.jpg~original
20161016_183448_zps6gvulciy.jpg~original
20161016_183614_zpsq4surdd1.jpg~original
Wanted to see where I was going next, so I did some layout with painter's tape.
20161017_165831_zpsfdffg20v.jpg~original
20161017_165847_zpsezksrx8u.jpg~original
Got started on the rear shock mounts. Shocks are 16"x2.5" FOA's. Using a behind the axle shock mount bracket from Barnes 4wd.
Had a bunch of grand ideas for shock mounts, but once I mock'd it up, a plan for a nice easy mount came together, almost like I had planned it...
Looks like I should end up with 6" uptravel and 10" down.
20161023_163341_zpseasy9a9w.jpg~original
20161023_163354_zpswzipuapg.jpg~original
20161023_165340_zpsudshvnsd.jpg~original
20161023_165353_zpsyue6djgn.jpg~original
20161023_181939_zpscyjefvuz.jpg~original
20161023_182023_zpskzhlcchi.jpg~original
20161023_182033_zpsj3jghjk4.jpg~original
I'll built a bracket in between the tubes. The hope will be to squeeze a 2"x2" airbump in as well, should be plenty of room.
Looks Good:awesomework:
Thanks Jon.
Little bit of progress.
Got the rear shocks mounted.
20161106_170112_zpsnpfsxkvm.jpg~original
Little bit of contact between upper links and seat bar mount at full bump that will have to get addressed.
20161106_170126_zpsgmzx338n.jpg~original
Started on the roof bars. Got the browbar in.
20161106_173433_zpsv5agpxhb.jpg~original
20161106_173444_zpsndhg0y1m.jpg~original
You sleeved the rearmost upper tube connection, right? If not sleeved and roset welded, it will crack with not much contact form something...ask me how I know! There IS a reason why I now have 2 support braces coming from the side tube...:redneck:
Yup, all the tube connections are sleeved.:awesomework:
No change, been busy with the holidays and honey-do's. Should get started on it again here pretty quick. Should get another pile of parts before long as well.
Haven't had much of a chance to work on this the last few months, busy with work and the holidays. But I have amassed a pile of parts:
For the Front:
2.5"x14" FOA reservoir coil overs
3 link kit w/7/8" heims from Barnes4wd
2.5"x8" Surplus Center Ram
22"Wx19"H crossflow aluminum radiator from Speedway
Set of Pacesetter headers (stock manifold is cracked to ****)
For the Rear:
22 gallon RCI fuel cell
2.5"x2" FOA air bumps
Still need to get a pile of steel to finish out the rear and start on the front.
20170224_194603_zpsgqxlfz8e.jpg~original
20170224_194610_zpsm6qvxppf.jpg~original
20170224_193704_zpsqomwkbk0.jpg~original
For the Front:
For the Rear:
Also been busy with completely destroying the old rig on the busy. :fawkdancesmiley::haha:
Worked on this a bit today for the first time in a few months...
got a 2.5"x8" Surplus Center Ram.
20170303_172027_zpslu2tr26a.jpg~original
Was able to take a closer look at some of the stuff in the parts pile. Kinda disappointed with the quality of the FOA shocks and bumpstops. But they aren't leaking oil yet and the price was cheap enough to put up with some cosmetic issues. Not sure on the dual rate slider with 2 short sides though...
20170304_163510_zpscavwuxio.jpg~original
20170304_163600_zpsf1wwlodp.jpg~original
Hard plastic pads on the bumps should hopefully mean they are at least somewhat quieter then the all aluminum style.
20170304_164036_zpsft2q9uop.jpg~original
Looks like they should fit good on the rear axle. Little worried about fitting 2.5" on the front, guess we will have to see when I get it all mock'd up.
20170304_171648_zpspfbsdwj7.jpg~original
Corners of the RCI cell are all beat up. Should be able to straighten them out though.
20170304_170347_zpsu83grel3.jpg~original
Threw the fuel cell in to see how well it fit. Fits almost like I had planned for it all along! Should be plenty of room behind it for tool/spare storage. It will sit an in and a half lower when it is all said and done. Plenty of link clearance.
20170304_171533_zpsjiwk3eqz.jpg~original
20170304_171558_zpsw5jcm7zn.jpg~original
20170304_171537_zpsixjpdlx9.jpg~original
Started mock'n up where I am going to add some more tubes in the rear.
20170304_172633_zpse2jcqxz5.jpg~original
20170304_172645_zpsllmoxx47.jpg~original
20170304_172654_zpsle7yxghd.jpg~original
Worked on tearing the body forward of the firewall today. Plan is to chop the inner fenders/core support off at the firewall and tube it out forward of there and the motor mounts.
20170304_180850_zpshdyfsidi.jpg~original
