bobbed_84_toy
ALWAY$ BROKE
Busted the #4 valve spring on the 460 in the Ford.:wtf: :wtf:
I was driving to school this morning and she started tickin a little bit. At first I didn't really think anything of it, just figured it was a rocker that needed to be adjusted. But then I remembered it was a Ford, not a chevy, you don't adjust the valves, you just torque the rockers down. Went to go to lunch and she started runnin really ****ty on me and I could tell it was down to 7 cylinders. Checked the plug wires and the cap/rotor which turned up nothing so I drove it home. Pulled the valve cover off the passenger side(it was poppin out that side) and looked for a loose rocker or a bent pushrod and didn't see anything. Pulled the plugs and #4 was a little darker then the rest. Stuck the compression tester on it and got a whopping 0lbs of compression
Checked compression on #1 and got 140 (which is good cause that means I have around 9.5:1 ratio
). Stuck it back on #4 and still got 0
I knew this wasn't possible unless there was a huge hole in the piston... and there were no chunks,shavings, or oil deposits in the plug:wtf: Looked a little closer at all the rockers and noticed the spring looked a little funny on the exhaust valve for #4. Sure enough, she was busted. I guess the comp cams 4x4 cam is just a little too much for stock springs???:wtf:
Now comes the fun part. Changing the spring without pulling the head:corn:
