Sold/Expired Buggy Chassis for Sale
BMan
Chassis and Protodie aluminum radiator, shroud and fan setup are left. Prices are OBO plus actual shipping costs. Shipping is via UPS from my zip 30062 except for chassis which is freight and we will figure that out. It is cheaper to freight ship to a business address.
If you purchase the Chassis I will throw in the Protodie radiator, shroud and fan along with pick up $300 of the freight shipping to you or deliver it within 4 hrs from Marietta GA. For the west coast folks, my research shows $300 in freight to a business address or shipping depot will get it about 1/2 way to California. To a resident address it is much more though. For anyone closer than California it may just cover the full shipping expense depending on location.
Paypal is my payment method of choice however creditable board members and established businesses I will accept Money Orders also. If shipped, payment in full is expected before its shipped and if I deliver it a non refundable $300 deposit will be needed beforehand and cash on delivery is AOK. Once we agree on the details payment is expected within a few days.
For anyone thinking about modifying it for solid axle mid/rear engine buggy I will remove the IFS/IRS setup and reduce the price to $1200. Some work of course would be needed for a sub frame for UCA/LCA but it is doable.
1. Tut Tech Two Seat Sand Buggy Chassis $1500 OBO
Main Chassis Details:
- 1.5" x .095 DOM tubing Chassis
- .120 wall DOM used for suspension tubes.
- Chassis is spot welded only for mach-up.
- IFS/IRS
- Front A-Arms with bungs.
- Front suspension tabs are mount.
- Trailing Arm rear suspension with grade 8 hardware.
- 17"-18" of Travel front and rear is possible
- Wheelbase approx. 94"
- Front WMS/WMS 73 1/2 - 74"
- Rear WMS/WMS 65 1/4"
- Currently all the mounts are there for a Hayabusa motor and an RPM gear box.
- Dash mounts for a Hayabusa gauge cluster.
- High quality notching and craftsmen ship!
Misc Fabrication parts included on chassis:
- 8 Tabs for seats.
- 10 Double shear harness mounts/tabs.
- 2 90 deg Gusset Tabs
- 4 Rear dual lower shock tabs
- 4 Rear shock upper brackets
- Gusset Tab Large Saddle from B pillar to upper engine bay hoop.
- 6 Trick/mount tabs with nut inserts in light bar.
- 2 Light Bar Tabs
- 2 Instrument cluster tabs.
- 2 tabs for rear of upper a-arms
- 2 tabs for rear of lower a-arms
- 2 Pre-drilled mounting plates for front of upper and lower a-arms.
- Light bar heims/adjuster
- 1 1" tube for steering (shown in pics laying on chassis across seating area)
Metal Fabrication Extras on chassis:
Extra tubes, gussets and metal work added to Tut's design:
- Custom Light Bar/Rack
- Upside down V at windshield.
- Rear shock mount tubes.
- Shock mount tube follows up to back to B pillar.
- Shock mount tube follows up as a gusset down to window tube.
- Lower belly corner tubes.
- Gusset tubes on lower engine bay area.
- Instrument cluster bracket
- Foot Throttle Pedal mount bracket/plate
- Tube and stock for mounting pedal assemblies
- Flat plate for motor and gear box
- Steering shaft tube
- Mount setup for CNC clutch and dual res brake pedals.
Material used for the above metal fabrication items on chassis:
- 15' of 1.5" x .095 DOM
- 15' of 1" x .095 DOM
- 5.5' of 1 x .120 DOM
- 4' 3/16 flat stock
- Mixture of flat stock and other metal used.
2. Protodie Honda Civic Race Radiator, Shroud and Fan.
- Asking Price: $110 OBO
- Original Price: $154
- More Details: Radiator, Shroud & Fan.
Pics:
Bottom A-arms in top of pic and top A-arms in the bottom of pic.
Whole chassis with light bar setup.
Chassis from the rear.
Dash area with extra tube for steering across chassis.
Brake and clutch (CNC) mount setup.
Harness and seat tabs, upper shock mounts and upper engine mounts:
Rear trailing arms, shock mounts and drive train mounts.
Quality of laser notching.
Rear of chassis.
Protodie aluminum radiator, shroud and fan setup.
Re: Buggy for Sale
Update in this post removed to decrease confusion since original post now contains the updated information.
Re: Buggy for Sale
I've seen this thing in person and it is very high in quality, tightest looking notches i've ever seen, guessing they were lazer cut or something? If you've ever dreamed of builing your own utv or a mini baja style racer then this is it, won't ever find a better deal than this one. Bolt a busa engine in and peel the fawk out!
Re: Buggy for Sale
Thanks Neal! You're right about the notches. I believe Tut was doing this with his chassis builds. :dblthumb:
Re: Buggy for Sale
Re: Buggy for Sale
What would it take to make it 4x4? Buddy of mine is looking for a buggy just like this but wants 4x4. I think he is really interested.
Toddy
Re: Buggy for Sale
Toddy
Short Answer: Some designing, thinking through and the parts.
Long Answer: We were looking at using SxS parts to finish it off but you can use other powersports drive trains too. Obviously all the drive train would be needed. Technically snow mobiles use similar CVT setups to SxS and you can mate a Hayabusa or other motorcycle motor to a CVT too with the right clutch setup or via an RPM gear box. Current knuckles are not setup for shafts so those will need to be redone. Front diff placement and steering design will need to be thought out. Not sure what exactly it'll take there. You could use certain IFS/IRS car diffs but the problem you still run into with car diffs is the width of them which impedes proper shaft length based on CV angles and plunge. CV angles being a big one. As the diff width increases you decrease the shaft length thus higher angles on the CV's. Maximum angles on these EMPI Chromoly 930 CVs is 25 degrees and RCV makes CVs with 28 degrees. So point being is if your shafts are to short then most likely you will not obtain the full 18" of travel and would have to take this into the design considerations.
Let me know if you have further questions sir! :dblthumb:
Re: Buggy for Sale
Re: Buggy for Sale
Re: Buggy for Sale
The original post has been modified and thread cleaned up a bit. It now shows the current items available and a great new deal! This is a steal ya'll! :drinkers:
