fireman108
- Joined
- Sep 19, 2008
- Messages
- 74
Blue Torch Fusion Chassis
99 TJ hood and grill
355 sbc with scat crank kit
lt1 conversion fuel injection w/24 lb injectors
52mm throttle body
block hugger headers
magnaflow 2 in 2 out X factor muffler
jims preformance harness and prom
tru cool aluminum radiator
be cool high flow fan custom fan sharoud
aluminum pulleys
krc power steering pump
110 amp alt
built 400 trans
2000 stall bm torque converter
modified 400/205 adapter
clocked flat ford 205 twin sticked
1410 rear yoke 32 splined 1350 front
ford dana 60 front cromo shafts yukon super joints
solid flanges
5.38 gears detroit locked 1350 yoke
psc double end ram
ator high steer arms
custom 4 linked
3/4 - 7/8 heims 1 3/4 .250 wall links
14" sway away coilovers w/resivor
double rate springs w/helper spring
dodge dana 60 rear w/yukon 1.5" shafts
disc brakes
BTF truss and cover
5.38 geared detroit locked 1410 yoke
16" sway away coilovers w/resivor
42" iroks on 16.5 trail ready beadlocks
12vguy switch panel w/circuit breakers and winch control
auto meter ultra lite 2 5/8 water,oil,volt,fuel guages
bm pro stick trans shifter ground to go from
drive to reverse
corbeau ss ultra seats
rci 15 gal fuel cell
all braided fuel lines
16 guage steel side,rear and deck panels
led rear tail lights
warn 9000 winch
asking $23,000
I am sure I forgot something pm or email questions not really looking for any trades right know
located in Winchester Tn
[email protected]
52mm throttle body
aluminum pulleys
110 amp alt
built 400 trans
solid flanges
psc double end ram
custom 4 linked
disc brakes
BTF truss and cover
drive to reverse
warn 9000 winch
asking $23,000
[email protected]
