onealdodge
- Joined
- Mar 3, 2008
- Messages
- 572
buggy is like new. I will trade. Looking for a lesser buggy trail rig for my son. utv/tractor/skidsteer/mini x-whatever you got
$40000
Lot's of high quality parts. Rig was finished in 2019 has been on 2 rides. Buggy has lots of clean detail and top notch components. All wiring and lines are clean. Everything is plumbed w/ braided lines and All AN fittings for fuel. Engine runs 205-210 at all times. All parts are new not off of a buggy built 5 yrs ago.
lots of interior room for short or a taller frame. I traded for this buggy and have found another rig. If the other rig sells before I sell this then I'll probably keep it.
Spyder Off road one off chassis powder coated black
Fresh built LS3 all ARP studded from crank up. 625 lift
Custom built headers with 6" bullets cut the correct length for computer tuning reading
FiTech Ultimate LS 750 HP kit-with hand held tuner for programming
PSC steering system
PTC built T400 and Tq converter brand new
Mid plate on motor and trans
SCS 3.0 straight drive transfer case with BKOR pinion brakes
All 1480 forged yokes and joints with balanced heavy duty drive shafts
Aeromotive fuel cell with Aeromotive in tank fuel tank 12 gallons
2.5" race series sway a way triple bypass shocks and coilovers on all 4 corners
Sway a way bump stops
B&M shifter
Mastercraft limit straps
All aluminum bead rolled body panels. console, interior, and dash all powder coated white
Smitty built xrc 9500# winch with eagle ram 1/4 clovis-vodoo rope winchline
7075 aluminum links all 1.25 heims
4.10 gear with yoke guards
14 Bolt front w/ 2" 47 spline RCV's spooled
Ouverson super 8 outers w/mega truck HD C's
14 Bolt rear spooled
Full built and balanced driveshafts
Raceline 17" forged double beadlock wheels
43" TSL SX stickies
black nomex radiator lines w/-20 AN fittings-coolant runs through frame to rear mount run cool radiator
Trans cooler
Memphis audio speakers with amp/ bluetooth
Overhead switch panel and audio control
oil pan to rear links is guarded with 1/4"steel belly pan. All hardware countersunk and stainless.
Autometer guages for oil pressure, engine temp, trans temp, volts, fuel
Kirkey seats w/ Simpson 5 pt. belts
HD diff covers f&r
Fire aid quick release fire extinguisher mount
Dual derale fans for radiator with shroud and one for trans cooler, computer controlled
Wilwood dual master cylinder and /pedal assembly dual calipers for crazy braking
Moroso oil accumulator
Summit battery kit-
Optima red top battery
Wheelbase is 121" belly height is 21"
Buggy is located in Bremen, Ga 30110
price is $49500
404-925-8515
$40000
PSC steering system
B&M shifter
43" TSL SX stickies
Trans cooler
HD diff covers f&r
Summit battery kit-
price is $49500
404-925-8515
