CCOR
706-559-9609
[size=10pt][size=10pt][size=10pt]We know the struggles that many of you go through when building a full blown buggy. If you've gotten to the point where you either ran out of time, patience, or special expertise then give us a chance to get your ride back on the trails!
We can setup link suspensions to convert from leaf springs or from a short arm setup. We work with Fox and PAC racing to setup our coil over suspensions and ORI Struts for our non coil over rigs. Both setups have their benefits and after sitting down and discussing your needs and objectives we will help you pick the right setup for your rig! We don't just put the links where they will fit the easiest, we actually run all the variables to determine your roll axis, center of gravity, anti squat, and more.
Here's a list of just some of the fabrication work we specialize in!
3 and 4 link suspensions
Full hydraulic and hydraulic assist steering conversions
Custom built axle assemblies: 14 bolt front axles, Fabricated 9" housings with dana 60 outters, 2.5 ton Rockwell's
Plumb and wire your Buggy projects!
855-572-GEAR Or 706-207-4140[/size][/size][/size]
