Sold/Expired Built dana 44 axles and other goodies
homerscj8
Got pics of most items
call 256-221-0487
north al
Front D44-- Passenger drop. BDS 4 inch Spring Under, Square u-bolts pointed up, Trussed, C's are rotated to achieve standard Castler angles and about 10 degree pinion angle. Chome-moly inner and outer shafts, 5 x 5.5 spindles, six bolt heavy duty lock-outs, KORE diff cover, High steer, Disc Brakes, Spartan Locker, 4.88 gears, seals, bearings, ball joints and spicer u-joints at knuckles all installed new with set-up. One spare inner and outer shaft. Brackets installed for Hydraulic assist shown below. Have about 4 trail rides and less than 3,000 road miles.
Rear D44. BDS 4 inch Spring Under, Springs have the shackles with them, Square u-bolts pointed up, Trussed, have one spare rear axle shaft, 5 x 5.5 spindles, KORE diff cover, Disc Brakes, Detroit locker, 4.88 gears, seals and bearing all installed new with set-up. Have about 4 trail rides and less than 3,000 road miles.
Both axles, springs, hydraulic assist steering and shocks and shackles., ready to mount under your jeep $2800. Rather keep the axles as a pair but will sell other parts individually
Have lots of heavy duty drive shaft parts, Rear and front with 1310 Cardigans $50 -$75 each
CJ steer sector for Hydro assist $100
ram 2x8 $40
.052 welding wire 44 lbs 2 rolls $40 each
vw beetle AC Kit (comp and coils) $100
4" BDS springs $175
BDS shocks $60
carb 1983 CJ8 $20
u joints Spicer 1310 $12 ea
dana 70 rear axle shafts $60
cj8 bulkhead $75
4.0 intake 1996 $30
JA250 pitman arm new in the box $40
Fly wheel 258 used $30
Anything your interested in? I will be at Little rock and hot springs next week. Could bring with me.
