Sold/Expired built fj80 front and rear axle
wizzo
glasgow, ky
abs knuckle front and full float rear. both axles have been completely gone through with new seals and bearings this year. no street miles, trail only.
front axle specs:
- set up for leaf springs
- custom steering setup using a rhd arm, custom hi steer arms utilizing the factory abs sensor hole for a capture point along with a step down in the arm to match the knuckle, increases sheer resistance. setup is similar to what slee offers
- knuckle balls have TG creeper gussets/ shock mounts, upper and lower
- marlin hd inner axle seals
- arp lower steering arm studs
- 8" hp third w/ detroit, 4.10 gears, triple drilled flange
- double ended ram mount
rear axle specs:
- 9.5" third, 4.10 gears, triple drilled flange
- hubs & axle shaft flanges have been drilled for six 3/8 dowels and six 7/16 cap screw bolts, replacing factory parts.
- anti wrap bar mount
axles will come with:
- full set of spare inner shafts & birfs for the front
- full set of rear full float rear shafts that have been drilled to mach the hubs
- spare v6 third for the front w/ welded carrier
- spare hp 4.10 ring & pinion
- spare 9.5" 4.10 ring & pinion
- random bearings and seals
steering setup pics
pic of the rear hub mod
don't mind the surface rust, they're get'n clean'd and painted
these axles are tuff! they have withstood 39" krawlers and 4.3 chevy (not like it's a ls or anything but more than a yota 4 banger). only problem i've ever had was sheering rear hub studs but that problem has been fixed! only reason i'm considering selling them is to build a buggy with v8 and maybe do some ecors race'n. if they don't sell i'll throw them under a chassis with the 4.3 and roll on.
price is $2500
located in bowling green, ky
