kmcminn
What will "well talk" mean? You might want to make sure your grammar is correct before you talk ****. JK. Good Luck With the Sale.
replied5.7yjuggy said:Pm sent
:****:jayphizzle said:Hey man im not tryin to get up in your business at all, but 3400 is a bit steep! Seems like you are trying to go the right route for yourself with the rocks though. You can tie up WAY more money in a Dana 60 front than a well built deuce front anyday! What im trying to say is that you may have to take a bit of a loss to move these. I know its harsh, but unless you are independently wealthy, then a little money is better than no money. Free bump anyway! Wish you the best on these.:****:
KPatterson said:Chevy 60
Yukon 5:38 Gears
Yukon Full Spool
Yukon 35 spline chromolly inners and outer with Yukon Super Joints (1 ride)
Mad 4WD Highsteer Arms
1.5" dom tie rod with 3/4' heims. Steering ram tabs(does not come with ram)
BTF diff cover
1350 u bolt style yoke
Mt Logan 35 spline drive flanges
1.5" aluminum wheel spacers puts it to 70.25" WMS
Good calipers, rotors, and pads.
Trussed to hell, setup 3 link with trackbar. Air shocks/coilover mounts
Super clean axle complete lug nuts to lug nuts ready to go $2900
14 bolt rear
Yukon 5:38 gears
Yukon full spool
BTF diff cover and pinion guard
1350 u bolt styler yoke
BTF bolt on caliper brackets with 3/4 ton disk brakes, nice shape
Ready to bolt into a YJ
Shocks mounts
Antiwrap mounts with adjustable antiwrap bar (2" .250 wall square tubing with heim at frame end and bushings at axle end)
$1300
Will not part out axles. All or nothing. I`d prefer not to split them up. Will drop them off at terminal if you setup shipping.
sent pmGut 3 said:$2500
