Sold/Expired Built Yota Axles For Sale
MattyB4x4
I've got a set of Toyota axles for sale. Would like to either sell as a set or whole before parting out.
Front Axle
OG 30 Spline Longfield Axleshafts
Trail Gear drive flanges
ARP Hub Studs
ARP Knucle Studs
Hi-Steer with 5th stud mod
4.10 welded third
Axle is set up for full hydro and will include 2.5" PSC single-ended ram and sleeved TG tie rod with FJ80 TRE's.
2.5" wheel spacers
TG Diff Armor
Front axle does need a new inner axle seal. Additionally, one knuckle stud loosed up and stripped out the hole. I have a helicoil kit to fix this.
Rear Axle
TG 4 link truss
4.10 welded 3rd member
Housing was shaved for additional ground clearance
Not much to this axle than that. The axle tubes do have dents in them from a tube truss that was on there prior to the TG truss. Axle shafts still pull out just fine. No performance issues caused by this - cosmetic only, as far as I know. Third member leaks, but could just use some RTV.
I was running plastic brake lines and calipers have been tapped to 1/8" NPT thread. It's very close to M10 toyota stuff and have heard of folks running M10 in 1/8" NPT and vice versa.
These were run in a toyota buggy for the past few years with relatively no breaks and only minor issues. They have been out of the buggy a while now, but I've listed the only known issues.
Price is $1,200 for all of it, including tie-rod and PSC single-ended ram. I'll throw in any and all spare parts I have including bearings, knuckle rebuild kits, misc. hardware, spare IFS rear housing, etc.
Located in Atlanta, GA.
What WMS are these with and without the spacers? would you post up a picture of the buggy they were in?
The front is a mini-truck standard Toyota width. The rear is an IFS rear so it is a bit wider (hence the spacers on the front). Its all standard built Toyota stuff
He has a bunch of pics, but I'll see if I can find some on my computer too.
If you go look at @partiallycommittedracing on instagram, its the little black Toyota buggy
