JNK-RNR
Miscalculated and now have 14inch 5125's for my FJ40:
Obviously the 14's are a little long, and logic says..it would be cheaper to buy shorter ones than fancy pants bump stops, but I believe I can make them work. Plan is to move the Ford shock towers to the top of the frame then gusset and brace it. Also going to move the lower shock mounting location to the side/bottom back side of the axle. That should give me about another 5 inches.
I am currently looking at:
Daystar Stingers: $209 a pair http://www.summitracing.com/parts/dys-ku71090bk/media/images
FOA 2.0: $300 a pair: http://f-o-a.com/shop/index.php?main_page=product_info&cPath=20_44&products_id=25
Sway-A-Way : $253.00 each so $506 a pair..:censor:
http://www.polyperformance.com/shop/Sway-A-Way-2.0-Air-Bump-Stops-p-17676.html
Fox 2.0: $201.00 each $402 a pair: http://www.polyperformance.com/shop/Fox-2.0-Air-Bump-Stops-p-63.html
Any other options? Suggestions regarding the bump stops? Or should I just extend the brackets for regular bump stops? Pro's cons of each?
