I run a Uniden HR2510
I converted it to run on teh 11m frequency range (pretty easy to do)
I have been known from time to time to add a little extra kick with a linear amp from time to time, but have not reinstalled any at this time.
been dabbling with these darn radios off and on since the early 80's...
102" stainless whip was, for the longest time, my favorite antenna, easy to match (SWR - signal to wave ratio) and the 1/4 wave antenna is one of the best 'hill climbing' antenna... meaning it was the best to send and receive the signals in hilly areas.
I now currently run a simple 'firestick' antenna, still easy to match the SWR and can handle any power if I decide to add it, they also don't smack around the old 102's do, which was a drawback to those.. some would 'clip' or 'tie' the tips down towards their rigs to reduce or eliminate this, but what a lot don't know is that greatly effects the signal capabilities of the unit.
always want to make sure that with any antenna or radio you run...
1. Use good quality coax cable - spend some money for the lower loss stuff
2. Always make sure your SWR is as close to 1:1 as you can get it... the higher it goes the harder it is on your radio and you can end up sending the radio in to get the output transistors (or finals as some call) replaced because they got burned up...
3. always make sure that all of your equipment, including the antenna, has a GOOD clean ground... magnetic mount antennas suffer in that department...
and if you want to add a 'power mic' (amplified microphone) to the radio, this will help people to hear you.. to a point.. it does not make the radio output any more power, all it does is increase the modulation of your voice making your voice louder. This is also only on the abilities of your radio, as at a certain point the radio will limit the modulation and start clipping.. sounds like garbage!!!
sorry about the long winded post there... just bringing back some old memories.. haha
