Cheap fender flares
japerry
Bellingham
This weekend, Tim showed me his neat fender flares to make his rig street legal. With a few changes, I adapted his to work on my 4runner with the cage.
1) Go pickup a semi-truck mudflap, 2x3ft is a good length. They're available at most NAPA stores. (I know the Bothell one has a few left ;-))
2) Each slice is 5 7/8s" wide, I used some masking tape and a box cutter to make the cuts. Its fairly straight if you have a steady hand.
3) Once they're cut into slices, match them on the truck. If you have a cage like me, get some metal self-tapping screws. drill a starter hole. Make sure you measure right, or else you'll have floppy fenders!
Once done, it'll look like this!
And there ya go. Parts list:
1: 13/64s drill bit -- ~$3
2: 16 self tapping screws -- ~.017 at mclendons
3: NAPA mudflap -- $10
Total price: ~$16 for all 4 corners.
that turned out sweet!!
Now your girlfriend's gunna think your ghetto!!! add that if they do rip off that you can spend an extra 17 cents and put em back on!!!
fust as an fyi, if you want the to be really legal they have to have a downward portion on the front portion of the flap. but looks good.
My gf was wondering about that. I figured that forward motion would keep the rooster tails from occuring, which is what the cops ultimately want to avoid.
But yah I might do that if a cop pulls me over =P
r.cw. rule
RCWs > Title 46 > Chapter 46.37 > Section 46.37.500
46.37.495 << 46.37.500 >> 46.37.505
RCW 46.37.500
Fenders or splash aprons.
(1) Except as authorized under subsection (2) of this section, no person may operate any motor vehicle, trailer, or semitrailer that is not equipped with fenders, covers, flaps, or splash aprons adequate for minimizing the spray or splash of water or mud from the roadway to the rear of the vehicle. All such devices shall be as wide as the tires behind which they are mounted and extend downward at least to the center of the axle.
(2) A motor vehicle that is not less than forty years old or a street rod vehicle that is owned and operated primarily as a collector's item need not be equipped with fenders when the vehicle is used and driven during fair weather on well-maintained, hard-surfaced roads.
[1999 c 58
looks like the flares are legit! =D =D
However, I'm not sure if my bumpers would bode as well... *goes out to check*
Damn.. front is 29" and rear is 35" :haha:
