cherokee wonders all over road but only at high speeds
2000xj
Member
Kent Washington
so i had a 4.5 inch lift on my cherokee and 1 ton steering and my jeep drove like a dream and so i just put a new 6.5 longarm lift on my jeep and now my jeep wonders all over the road i just put a new steering box in it and put the drop pit arm on and it took away my bump steer but still wonders any ideas on what it could be.
Get the wondering ***** on an alignment rack! Unfortunately the bigger the lift, the less of a road machine its going to be. And also check for some slop in the steering, some loose or worn out. Good luck :awesomework:
ya i am sure the lift has change the caster and i still havent got an alignment from when i put the 1 ton in i just got it close with a couple of 2x4's and a tape measure so should probably start with that and then check to see if everything is tight. thanks guys.
