Chop cut rebuild
Finally got around to working on the rear disconnect shaft
The latest on chop cut rebuild Chopped and rebuilding a rear axle
paradisepwoffrd said:
Is that disconnect parts from a CAD axle?
I built the disconnect. Gears came from Toyota transfer case
Although using stuff from a CAD axle would probably work good
Re: Re: Chop cut rebuild
Gotcha. The fork and collar looked like something repurposed from an axle, tcase or trans.
Are their synchros on it? Are you going to enclose it or leave it exposed? Cable/lever shift or air/elec?
Buggy is getting better all the time, and one I would love to have for sure.
It will be exposed and operate with air cylinder
Looks like a shift fork from a 231. Good looking Work tho. I'm anxious to see how that works
The rear steer axle is now assembled and ready to install under the buggy
