CJ7 Juggy
bfrazier!
Member
Sold Sold Sold
1984 Jeep CJ 7 juggy
AMC 401 eng.
Forged crankshaft and connection rods
Internally balanced
Heads milled & pocket cuts on valves
Block decked
High pressure & high volume oil pump
Oil pick-up tube modified to prevent oil starvation on vertical climbs
Crane RV cam
Elderbrock performer 4 barrel intake manifold
Complete eng. Overhaul by Duffin Eng. Shop
Mean-Green HIGH TORQUE starter
M. O. R. E. OFF ROAD solid motor mounts
Four core radiator with chevy 454 fan clutch and aluminum shroud
COOL FLOW High flow water pump
Accel high output ign coil
Propane system
Impco 450 four barrel carb and impco regulator
Balanced and tuned by Tim Westerdale
5 tanks total
Sunray Engineering Chevy dana 60
Full Detroit locker
Moser 35 spline chromemoly inner axle shafts
Yukon 35 spline outer chromemoly axle shafts
Warn lock-out hubs
Crane heavy-duty front cover
5:38 ratio
Sun Ray high steer arms and narrowed housing with tie rod assy. Behind diff.
Sunray Engineering Ford 9 "
Housing shaved and narrowed by Sunray
Full spool
35 spline Moser chromemoly axle shafts
9" Nodular case
727 transmission built by Gary Howard
RV torque converter [1200 RPM fully loaded]
Clutches , Bands and sprag clutches up-dated
Reworked valve-body
Dash mounted Transmission temperature gauge
Lokar transmission shifter
Remote cooler with fan
Atlas Transfer case 4.3 ratio W/32 splines
Atlas cable shifters
PSC Hydro assist steering kit
Steering Box
Power steering pump
Steering cylinder
Reservoir with filter
Flaming River stainless steering shaft
Vanco hydro-boost Brake system
Front Chevy ¾ ton disc brakes
Ford drums brakes on rear
15" Trailready Beadloks
39.5 Iroks
Rear suspension -Single triangulation 4 link rear with coil springs
Front BDS leaf springs
Wheelbase is 114"
MasterCraft Rubicon Seats
4 point harnesses
This jeep was built from a stock CJ by the previous owner.
Same gentleman built and meticulously maintained it for the last 20+ yrs with a strong attention to detail. It is a very solid rig with some bumps and bruises as seen in the pics.
Price is $ 9,000
Located East of San Antonio Tx
Trying to post pics ???????
pics
Comes with 5 aluminum propane tanks and a damn near new 39.5 Irok mounted on a steel wheel.
