CCOR
706-559-9609
[size=10pt][size=10pt][size=10pt][size=10pt][size=10pt][size=10pt][size=10pt][size=10pt][size=10pt]Tired of having to source all your axle parts from multiple sources just to try and find the best deal?
Look no further the CCOR 14 Bolt Package!
It comes with the following!
GM 14 Bolt High Clearance Shave Cover
The 14 bolt is a great axle. They are cheap, strong, easy to find and cheap to build. However they have always had one down fall, that huge lip on the bottom that get hung one ever thing on the trail. Barnes 4WD has come up with a solution to this issue. Our GM 14 Bolt 3/8" Shave Cover. This cover will give you more than 1 ¼" of ground clearance. Another thing that makes this a great shave cover is that you will not need to have your gears turned or perform a complicated welding or machining process that just adds more cost to your axle build. All that you will need to do is bolt the diff cover to your axle and cut off the extra lip. This can be done with simple tools that you have and you can do it yourself and we GUARANTEETHEM FOR LIFE! Like all of our diff covers they are made from 3/8" plate and machined flat after they are welded to insure that you will have a flat surface to mount to your axle. We do recommend using allen head bolts on our GM 14 Bolt Shave Cover.
Disc brake bracket bolt on
Artec 14 Bolt axle truss with pinion guard and bridge.
4.56, 4.88, 5.13, or 5.38 Ring & Pinion
Master install kit with all new bearings for center differential.
Full Steel Spool!
Total Price $1129 with FREE Shipping in the Lower 48!
That's a savings of over $170
If you want to upgrade your shafts to 4340 then add $385
Total would be $1514
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140[/size][/size][/size][/size][/size][/size][/size][/size][/size]
Full Steel Spool!
Thanks,
Bobby
Sales Manager
CCOR
