Edit- if it's got a price listed after it then it's still for sale.
Must sell my buggy project, being laid off SUX.
Complete tube chassis out of 1.5" hrew .120 wall.
Was building it for 4.3/700r4 and a WB of 115-120.
All link tabs are welded on the chassis.
Seat bracket and tabs are there too, set up for corbeaus.
Winch mount welded on too
Shock tabs are in place also
*chevy 4.3 from a 1992 Blazer w/new timing set and water pump,
Wiring harness and computer included, could use new distributor and a tuneup. $350 for 4.3
* 700r4 short body K case from the same blazer, also have the 231C if wanted with it.
Blazer was running and driving when it was all pulled.
* All new wide track Dana 44's with new disk brake setup, 5.38 gears, spools, chromos front and rear,
Rock crusher diff guards, trussed f&r, link tabs included, hydro setup on front. New MileMarker lockouts ( everything is new in them )
* 39" BFG Red Label Krawlers on 6-lug steel bead locks, NO holes or patches.
* All link bars (.25 wall) are included, as well as 8 super joints and 8 heims (3/4) with
Misalignment spacers and bolt, bars already have bungs welded in for Heims and super joints
* Currie Anti-Rock sway bar.
* 2 fox 14" air shocks 2.0's (new), 2 king 16" coilovers 2.0's (lightly used).
* 2 Corbeau seats
* New Summit 13 Gal fuel cell.
* Wilwood dual brake setup 1x7/8" bore & 1x1" bore.
* New disconnect steering wheel, w/bung.
* Eaton 4-port orbital valve
* Griffin aluminum radiator with electric fan and tranny cooler mounted to it.
* 9,000# Warn winch. $350
* New in box B&M Sport shifter. $160
* New 4 in 1 multi gauge.
* Pre-wired and fused switch panel.
* New 34" LED light bar (flood/spot combo)
I was building the buggy I've always wanted: 4.3, auto, built 44's, stickies, very light weight!
I'm really not wanting to sell but I have to. I've got well over $10,000 in parts and chassis.
Just needs put together and plumbed.
$8,900 takes it all.
Call or text (865)617-623zero
Located in 37756
Update, Sold parts:
Chassis
Seats
Fuel cell
Steering wheel
Switch panel
Light bar
Gauge
Currie sway bar
Orbital
700r4
King coilovers
* 2 Corbeau seats
Located in 37756
Update, Sold parts:
Chassis
Seats
Fuel cell
Steering wheel
Switch panel
Light bar
Gauge
Currie sway bar
Orbital
700r4
King coilovers
