tommy450r
Cucv 60
Yukon chromo axle shafts
Yukon chromo u joints
Yukon drive flanges
Barnes 4wd high steer
Trussed for double tri 4 link and coilovers
Stock cover that's been beefed up
It's got a bad r&p 4.56
Mounts for double ended ram
Welded carrier
$1650.00
The dana 70 rear is in working order pulled out of running driving truck. 4.11 gear I think?? I've never had the cover off.
Dyersburg TN 38024
It's still under my buggy as of right now but it's quick and easy to pull out. only has about 10 rides and I was told the cucv it was pulled from ony had 30k miles. I gave 1000.00 bucks for the stock axle and put about 1500 more in the add ons and now I'm going to a 14 bolt front. The truss is bent a little bit but does not effect anything it's been braced up a lot since the bend I tied the truss and ram mount together and added a backing plate...
Yukon drive flanges
Welded carrier
$1650.00
Dyersburg TN 38024
