1990 Jeep Cherokee Laredo
4.0 liter
AX-15 5speed
NP231 transfer case
Novak transfer case cable shifter
4 linked with coils front and rear
New Rubicon shocks and limiting straps in the front.
New Rancho shocks and limiting straps in the rear.
Dana 60's with kingpin axles, welded 4.88 gears
39.5 boggers (60% tread) with beadlocks
9,500 lb Champion winch with remote
15 gallon RCI fuel cell with external electric fuel pump.
Removable doors
Aftermarket head unit, speakers, amp (not installed yet)
CB with antenna
Dragon Fire harnesses in the front
RCI racing seats and harnesses in the rear.
Currie anti rock front sway bar (not installed yet)
Hydraulic assist steering
air & heat
have ***le
Update: Rear end started growling. I pulled the diff cover and it had water in it. Probably going to need a new bearing kit. Maybe I am shooting myself in the foot trying to sell it with a growling rearend, but I just don't have the time or knowledge to replace the bearings. I think you can get a bearing kit for $125. Maybe you decide you might has well replace the ring & pinion while your at it. (There was some pitting from the water). I think you can get a set for $250. So I drop the price $400 and we make a deal. If you can get past the growl I think you will see a pretty capable rig.
Runs great, goes anywhere. I might be able to help with delivery depending on my schedule and your location. Call or text me @ 402-432-6808 for questions or more pictures. Asking $7,500. Located just outside of St Louis in Foristell, MO. Thanks, Steve
4.0 liter
AX-15 5speed
NP231 transfer case
Removable doors
CB with antenna
air & heat
have ***le
