sexxy
- Joined
- Apr 22, 2013
- Messages
- 631
I have a d44 from an early 70s f100, has high pinion drum brakes and is wider than I want. I also have a d44 from a 79ish scout ii, with disc brakes and the width I want. Is it possible to disassemble both housings and use the long side scout tube on the ford on the opposite side or do I have to swap the inner "C" as well? Trying to get info and game plan before tearing into things. It will be going under a tj that I dd and beat merciless on the trail. The d30 has seen to much breakage and I dont plan on anything bigger than 37/38.
