slednecks1124
- Joined
- Aug 16, 2006
- Messages
- 1,544
Hey guys,
I've got a 93 jeep wrangler with stock axles (dana 30 front and 35 rear), I keep having a problem with the pinion yoke breaking. The rear still has the cheesy strap style retainers for the u-joints. This last weekend was the first wheelin trip since i welded up the spider gears in the rear an the yoke was the first thing to fail.
Seems whenever i get on it real hard this happens, the tabs that hold the u-joint from going side to side keep breaking off and the bolts that hold the straps to the yoke break as well which results in the driveline coming undone from the rear end.
I have been doing a little research on the net and it sounds like the u-bolt style straps is the way to go and should cure such problems. I was also told that a yoke from a dana 44 will also work and is a little beefier (also already has u bolt style straps). Anybody have any useful advice for such problem?
I am going to get a new yoke an convert it to the u bolt style straps this week just wondering if there is something else that may help this problem.
I know the dana 44 swap or something may be the best bet but I'm just purchasing a new house so that is out of the question at the moment.
