Barnes 4wd
- Joined
- Aug 29, 2013
- Messages
- 399
Dana 44 High Steer Arm Kit
Your search for the highest quality Dana 44 high steer arms at the lowest price ends here, we offer the most complete kit available. Our Dana 44 high steer arms are machined from a solid piece of steel right here in the good ole U.S.A.
The arms have the proper angle machined into them to insure that your tie rod ends will not bind when your suspension cycles. The passenger arm has two holes one for your drag link and another for your tie rod, the driver arm has a single hole for your tie rod.
This kit includes both arms and all the hardware that you will need to mount your arms (if you select the hardware option). Your arms will arrive raw and need to be painted or powder coated.
