Sold/Expired Dana 60 3/4 ton front brake kits
gubni
www.lugnut4x4.com
Jonesborough, TN
Why should you convert your front axle to 3/4 ton disc brakes?
1. Better clearance for wheels
2. lighter weight - about 41lbs
3. firmer feel of brake pedal
4. still can stop 44" tires
5. clears most 15" steel wheels with 3.5" or less backspacing
I off these kits for Ford, Chevy, and Dodge kingpin axles with external lockouts. It even works on a Ford balljoint axle up to 1997.
New and improved design now works with all known aftermarket knuckles including Crane Knuckles.
I don't think the will work on older drum brake front axles.
This is a complete kit and includes:
2) GM 12.5" rotors,
2) 3/8" brackets
2) GM calipers
2) caliper pins
1) set high quality semi metallic pads
4) copper washers
2) banjo bolts
2) new wheel seals
The ford kit uses a 1/8" spacer bracket which is included and goes between the bracket and spindle.
The Chevy kit bracket mounts outside the spindle like the original factory design.
The calipers are 1980 Chevy 3/4 ton 4x4 front JB6 calipers. The pads I ship are a very high quality and should do very well on the street or on the trail. The rotors are stock from 1980 Chevy 3/4 ton K20 4x4.
The price is now $295 shipped.
Need brackets only? $100 shipped (This option is not on my site since I focus on selling complete kits.)
Need hoses? Braided stainless hoses 18" long are only $60 more for two.
Chevy kit shown - Ford has 5 holes for spindle and a spacer.
This is a great option over the 1 ton front brakes and stops just as well. The factory brakes are great for a truck that is hauling a big trailer with lots of weight, but the 3/4 ton calipers can still lock up a 44" tire on a trial rig.
Bump for a great brake deal, I bought a set and swapped over last year. No more Ford caliper bracket stretching out, rattling calipers. The stop my rig great and the pedal does feel better.
Didn't you used to sell dana 60 fronts? If so I'm looking for a Ford Dana 60 from 78/79
Thanks,
Bobby
Thanks,
Bobby
Yes that's me, lol. I have one on the way to you now. I'm still looking for another, but no luck.
Been running this setup for about a year on my 79HP. Money well spent to remove that Ford crap from my axle. Seemed like no matter what I did once a year I'd drop a caliper. Luckily I got this setup before I ruined a rim
same here, 100x better
