Dana 60 - 70 shafts?
Maverick26
As iron sharpens iron...
Silvana
I got a few questions before I start building my new rear axle. I have a Dana 70 and a Dana 60 and I would like to use as much parts of both as I can. My idea is, use the 60 housing, buy a dana 60 35 spline spool but can I use the 35 spline 70 shafts?
The 60 had 30 spline shafts in it when I got it. If I can make it better I would like to. I looked on Randy's website and they sell 35 spline 60 shafts but no where does it say the dia of the shaft. The 30 splines and 35 splines are way different dia along with 5 more slines. What can I do with this pile of parts?
What about using the 70 and just trimming the bottom of the housing for extra clearance? Weld the spiders and sell the 60 for some extra cash. Just an idea.
The 60/70 shaft length is probably different. Stock 70 shafts neck down and cannot be shortened. The 60 spindles might need to be drilled out for the 1.5" dia. shafts.
It says on Randy's that the Yukon rear shafts will fit 60, 70, and 80. The flanges are the same BP. Im going to narrow the 60 housing anyway so If I cant cut down the 70 shafts I guess ill be buying some Yukons 35 spline. Im assuming if I get a 35 spline spool everything will fit.
If you have an extra front inner shaft hanging around then do this,
Remove one rear 30 spline axle shaft. Then try to slide the 35 spline front inner thru the spindle. If it does not fit then you will need to bore the spindles.
To get around boring the spindles just use the 70 tube ends and outers on the 60 housing when ya narrow it and then ya dont have to bore the spindles and make them thin.
X2
If your already in the process of narrowing the rr axle, than I totally agree:beer:. But with the stock 60 housing and 30spline shaft you will need to bore the spindles....
http://eastcoastgearsupply.com/i-157258-dana-60-spindle-boring-tool.html
Have fun chucking that up in a 1/2" drill :haha::haha:
A buddy of mine piecing togethor his rr 60 for really cheap and this was one of the options to get those 35splines to fit. You can pickup 35spline open carrier 60s from semi float 60s ($30 at pickapart) in early 80s fords than use the 35spline shafts from dana70s ($20 for both!), open up the spindles and you have a strong cheap rr 60...
But i will always be biased towards the shaved 14bolt.... just makes sense to me:redneck:
The difference from the Dana 60- 70 housing isn't much. Yeh the housing itself is beefier and slightly bigger but the actual ground clearance is only about 1/2" from the bottom of the tube to the bottom of the housing. JFYI
Lots of great info guys... thanks a lot.
My plan is to retube both my front and rear 60s with 1/4" wall tube, then do the 70 spindles on the rear, spydertrax knuckles on the front. I think I am going to go with ARB in the front and spool in the rear. Staying with the 4.88s that I have now. I am 67" WMS right now cause they are dodge axles, so I think I will bring them down to 63", IIRC that is what most folks run width wise?
My goal is to shave as much weight as I can on my rig... personal challenge of mine with everything I do. Thanks for the help, Im sure I will have more questions. I will update with pics when I start my project in a few weeks.
Why would you want to take away the strength by going .250wall tube on the front? Or the rear for that matter??? I see you want to save weight, And I suppose if you truss 'em they'll be ok...I like the stance your rig's got at 67" WMS....but hey, it's your rig!!!! :redneck:
I love the look and handling of the fullwidth WMS but squeezing through the trees and tight spots can really become lame, especially when your following narrow rigs on the trail. I like the idea of 63" wms, thats what ill be sittin at when i finally get around to narrowing my axles....
67" is nice for some things but it is just a little to wide for around here. I think I can gain some nimbleness if I cut it down a little. As for the .250 wall tube, it is plenty strong, most KOH guys are not running anything thicker. Im still doing research but that is the way I think I will go.
Will your tires be rubbing on everything at 63 wms? Im 65. Wanna sell the 70 complete?
Im not sure, 63" would put me 2.5" narrower on each side then I am now. 65" would put me only 1.5" narrower. I could always inbd my lowers a little and shocks if I need to. Widest point of the chassis is 54" so it will still be 4.5" wider then the tube. Ill let you know about the 70. If I can get 35 spline shafts to fit in the 60 spindles then ill sell it complete.
I dont know... maybe Im high and should not even waist the time or money on a few inches.
If you are trying to save weight I would not go for ff hubs in the rear.
Most .250 wall axles at KOH also are larger dia like 3.5 to 4.
Well ****... I dont want to go that far... Hell I might not even take the time to retube these axles. I may just cut them down and call it good. Im really just trying to learn as much as I can before I start. The biggest reason for the rebuild of my rig is when I built it in the first place I didnt know what I know now. Anyway...
Once I start taking it apart I will start to figure out what way I want to go with this project. I know I want to stay 8 lug and FF, and I want to run 35 spline.
All 60-70-80 don 't have the same axle flange so check what you have before getting too far. Also. 250 Wall is not strong enough so don't go there.
