garagefab$
Active Member
so no one makes a dana 60 pinion cover and I want to after seeing rattle rock. I watched a couple dudes slam into their 14 bolt ones and they just plain saved the day. so my plan is to get the block machined and build the rest. does anyone out there have machining skills that could make me a couple. can you quote me on the cost of QTY 2 machined pieces to make a Dana 60 pinion guard (Mild steel) or what you recommend. I just want to get the block of metal machined and I can take care of the rest. block of 1in machined to fit over the pinion then machined in the back to fit over the oil passage. I can take care of the drilling and tapping and also cutting it in half. Then I can bend up some plate and weld it to it. i can get you more specific measurements and also a drawing if we go forward with it.
