Dirt Track Shifter On TH350
DUNCAN74
Does any body know the best way to go about hooking up a dirt track shifter to TH350?I know i will have to buy cable and linkage but want to buy it right the first time any input would help thanks!
Get the arm for the transmission, and a rod/heim kit. Bolt it up and adjust stop for reverse or park.
At the TH350 you need one of these for $4.99
http://www.speedwaymotors.com/Transmission-Shifter-Arm,8442.html
Or you can buy the whole shfier, linkage and arm for $49.99
http://www.speedwaymotors.com/Stock-Car-Automatic-Shifter,2801.html
Essentially offroad sells their own dirt track shifter for Turbo 350 that has a cable instead of linkage and price is good too!
http://static.speedwaymotors.com/RS/SR/Product/91021956_R.j
[url=http://www.speedwaymotors.com/Stock-Car-Automatic-Shifter,2801.html]http://www.speedwaymotors.com/Stock-Car-Automatic-Shifter,2801.html[/url]
[img]http://static.speedwaymotors.com/RS/SR/Product/91021954_L.jpg
So this set up works well with the TH350 would like to see pics if anybody has some?
i put this setup on my smith buggy with th400 and i also put it in the spider buggy with a th400 and both have tci dirts track shifters....work great, no bull, nothing to go wrong with em...
Ok I have already bought a daymotors shifter. But i guess i can get that TCI shifter It looks better any way plus it comes with everithing also thanks by the way for the info.
I ran it, only thing I didnt love was no "park lockout"
I really dont have good pics, but here you can see the shift tab on my TH350 behind the framerail repair I had to do.
well got to looking at the shifter and not going to be able to go with the rod setup.The way my shifter is mounted have to use a cable?So i will prob be giving Jimmy P at EOR a call about his setup?
Found a pic from a while back.
You can see where the Tab and rod come off the TH350, then to the tab that hung down under my seat that rotated on a rod that my shifter was attached to that stuck up between the seats,
With my seats in you can see where the shifter sits.
I like how u have that but i have like a console that sits on top of the floor pan have run cable thru holes to transmission thanks for the help!
I built my own "dirt track" shifter for my rig no stops or anything fancy. Im not sure how it would work for one of the real ones, but I want to say it was the 6ft B&M cable/arm/trans bracket from a ratchet shifter that I'm using. It might be longer, Ill eyeball it again and try to get a picture in the morning.
I tried to order a kit from eor but they haven't got back to me yet. Gonna try them one more time before I order a cable and make my own.
