Well i have an 85 toyota front axle im assembling. I got a really good trade deal on an E-locker so i decided i was guna run it in my front axle, and possibly one in the rear as well.
Currently where i'm at the axle is all trussed and i have the housing all trimmed and have the third fitting well into the housing. While researching all over forums I've been hearing about sidegear breakage being the main problem with these lockers. Some were saying that it was due to poor spline engagement on the long side causing the sidegear of the third to break. I guess this is due to the fact that Tacoma axles have longer shafts than the pickups therefore the pickup shaft does not fully engage the splines on the sidegear. I have on the other hand heard that it's just due to the poor strength of the sidegear.
I have a brand new set of longfield 30 splinse and hub gears im planning to use in this axle. So basically im wanting to know if i should just slap the longfields in and run it. Also i want to know if anyone out there running E-lockers has had lots of problems breaking them or is it pretty uncommon? Is there anyway to remedy the spline engagement problem other than custom length shafts? I've heard of people cutting down their axles a 1/4 inch on each side but is it really worth it?
And please don't preach about ARB's cus i know they are pretty much superior but i can't afford them right now :fawkdancesmiley:
Here are the plans for what the rig will have just to give you an idea
98 4.3 mated to TH350
Dual Toy cases with 4.7
Tires will be at least 36's, 40's max
Probly weigh about 4500
