ECGS
Kit Includes:
Single Rear Wheel 3/8 Bracket
Mounting Hardware for Brackets
Left and Right 1/2 Ton Calipers
New Brake Pads
New 8 Lug Rotors
Two 12" Long Braided Stainless Lines
24" And 18" Long Hard Lines
Mounting Hardware for Brake Lines
Hub Seals
Hard brake lines only come flared on one side to accommodate for different vehicles and brake line set ups. Some grinding may be required on caliper based on how brake lines are run. No provision for e-brakes.
THIS KIT WILL ONLY WORK ON SINGLE REAR WHEEL APPLICATIONS!! DOES NOT WORK ON 1989 AND NEWER AXLES! $315 shipped with stainless lines.
We also have a universal weld on kit with Weld On 3.25" Diameter Brackets that is $305 shipped.
Pirate Members discount code is "BRAKES" for the Bolt-On kit and
"UNIVERSAL" for the Weld-On kit.
Both products can be seen here Universal 8 Lug Disc Brake Kit - http://eastcoastgearsupply.com/i-12027795-gm-14-bolt-disc-brake-conversion-kit.html
