Sold/Expired Elderfab YJ Buggy(SOLD)
Pineygroveoffroad
Somerset Ky
Elderfab YJ Buggy
Jeep hood and grill narrowed
Aluminum side panels
Aluminum floor and firewall
Aluminum dash with oil press., water temp, volt, fuel gauges
Summit battery master switch
Quickcar switch panel for ign., fuel, fans and lights
Rednecklights 12" bar on fr 6" r
Optima redtop battery
Kirkey 18" prostreet seats/covers
G-force 5 point latch/link harness
LQ9 6.0 with cut harness converted to speed density
Headers, Melling oil pump
RCI fuel cell w/ Artec brackets
Aluminum Radiator
Alum. fan shroud w/ dual fans
TH400 trans. manual valve body
B&M shifter
Moroso locking dipstick
Trans cooler w/ fan on thermostat
NP205 transfer case
Twin stick shifters
NWF clocking ring
Rear tcase mount
Dana 60 fr axle welded diff passenger drop low pinion 5.38 gears
Chromoly inner and outer 35 spline axles, spicer axle joints
Rpm drive flanges
High steer arms arp studs
Btf diff cover/ hydro ram mount
Eaton orbital, PSC pump & res.
Double sided J&B hydraulic ram
14 bolt rear axle
5.38 gears
Yukon 30spl spool
Thick fabbed diff cover
Disc brake conversion
Fox 2.0 coilovers w/ viper springs
14" travel on the front axle
Fox 2.0 airshocks 16" travel rear
Currie anti-rock bar
Triangulated 4 link fr&r
Smittybilt 12,000lb winch
117" wheelbase
42" TSL SX 2's Aetna cut
Recentered H1's outer rock rings
Inner bead stiffeners
Pvc inserts
(5) wheels the 5th has a junk 42" tsl spare on it good enough to get you out of the woods
Only selling to buy a house. Might consider a cheaper 4cyl buggy or cheaper trail rig or maybe a nice RZR on trade with boot my way.
Located in Somerset Ky
Ph # 606-305-4533
$16,500.00 OBO
Re: Elderfab YJ Buggy
Is there any videos of it in action and how long have you had it on the trail.
I don't have any videos. I've had it about 2 1/2 years
I fount a couple videos if you have the ye ol grand Facebook look on my page Shane Mounce
Links are 1"3/4 thick wall sleeved lowers uppers are a little bit smaller dia tubing all with 3/4 Heims and misalignment spacers
Video from couple months back...
https://m.facebook.com/story.php?story_fbid=585593938303083&id=100005574450898
PowerLine Hill @ Pumpjack Off Road....
https://m.facebook.com/story.php?story_fbid=585593981636412&id=100005574450898
Another pic...
https://m.facebook.com/story.php?story_fbid=501733076689170&id=100005574450898
