FJ40/TBI 350/2wd 4L60
JNK-RNR
Cottage GrOrego
Hi all,
That would be a great drive train swap into a FJ40! :awesomework:
The problem is that link goes to an AA adapter for a 700R4.
-Alan
Hi all,
-Alan
One lists 4L60, the other lists 700R4 then states 4L60 I thought..lemme double check...
yeah you have to click on the lil drop down thingy and read the bottom part about the transmissions " his kit is designed for exclusive use with the 2wd 700R-4 / 4L60 / 4L60E manufactured thru 1996 "
Is the output on that T-Case off set like the early 3speed FJ40 T-Case?
More info, Vin#1G1BL5371NR113540
http://www.policecars.us/caprice9c1vin_decoder.html
Made in Arlington Texas.... 'Merica *****es!
7 = L05 5.7L - 205 HP @ 4400, 300 lb-ft @ 2800 (9C1 Police)
7 = L05 5.7L - 180 HP @ 4200, 300 lb-ft @ 2800
Yup. I think the split case would be the way to go since you will be having to buy an adapter either way. That way you won't have to worry about my kind of "split" case. :redneck:
I have a buddy up here parting out an 82 Fj 60..the case is mine if I want it. My head is spinning. I cannot find any threads right now on this conversion.
And now a guy I work with just offered me a 2UZ-FE complete drivetrain, wiring harness and ECU for $800..to much involved in that swap but it would be a screamer.
Hi All,
The "split" type t-case from the 1982 FJ60 would be a good choice; it has a low-range of 2.28 to 1 (IIRC) unlike the 1.99 to 1 of the later "split" 'cases.
Regards,
Alan
