FJ60 build
brokenparts
Hillsboro,OR
been hiding on the forum off and on for awhile and I'm bored today so I decided to drag my build thread over here. Anyway:
Here is it before when it was SUA and on 36s with a TBI 350/4speed/toybox to splitcase:
then I sprung it over and got it 39s and a th350
that led to a d60 with full hydro steering, rear d70, 203/205 doubler, etc.
I ended up tearing down my th400 to swap the output shaft to work with the 203 input:
To make everything work for a 203/205 I had to get the right output and adapter.
removed the pump bolts:
I reached up with the back of my ratchet and ever so gently popped out the pump:
next I pulled the pan:
which exposed the valve body:
and the roller thingamagig:
speedo:
then pulled the valve body... the suggested way was to do them evenly:
this was in one of the valve body tubes:
valve body on the table:
and what's underneath:
lots of little paths and steel balls:
removed the servo:
now it got interesting... I tried to pull everything out in chunks.
First was the foward clutch which came out pretty easy:
and out
and then the direct clutch. it was also pretty easy to remove:
I forgot to take a picture of removing the band but basically there is just a little pin to move and then it come straight out...
then the intermediate clutch. Kinda tough to see but there is a snap ring that you have to move past the little stops:
then the biggest pain... the center support snap ring.
but I won:
then I took the planetary out and removed the snap ring and switched the shafts:
planetay with the long shaft
the guy on pirate clamped down to remove the snap ring so I did the same thing:
the two shafts compared:
new shaft installed:
the mess:
then it was time to pull the fj gear:
pulled the toy junk... adaptor, toybox, splitcase. I
I got the d60 somewhat postioned under there:
some more pics of the th400 going back together and some other progress pics...
trim lines:
Bumper looks like it'll be for sale soon:
Front shot:
started taking the H1's apart:
Got the shift kit installed. I went for the "street" shift which is supposed to be the most firm. I hope that it doesnt end up breaking my teeth when it shifts:
Primed:
Painted:
little more progress with swapping some of the 205 stuff.
Case:
Tear down:
front output out:
old vs new 32 spline:
Rear tailshaft assembly
this needed to come out
off:
I remembered to account for the fatty needle bearings (15)
apart:
Removed the shift rail pins:
then frustration set in... I could not get the shift rail out. Before I knew it and had the BFH out and started pounding on it. Still nothing. I decided to take a break and quit pounding on it and see if there was a better solution to getting it out.
then I got the ol' sawzall, plasma, and grinder out to start to remove the old brackets:
cutoff the old exhaust:
ThenI put some more work into swapping the front output shaft to the 32spline:
needle bearings are a pain:
buttoned up:
started putting the 203 doubler stuff together:
ARB came... Randy's ring and pinion is cheap and fast!
More on the 205:
Shift fork installed:
then I had to back up... forgot to install the short input shaft first:
then the fork and sliding gear:
together:
snap ring installed on other side:
then the shift rail pins by lining up the forks and the holes in the shafts:
then installed the bearing and snap ring on the output shaft:
the stuff for the output shaft:
it was easier to prop up the case to drop it in:
looking down:
then the thrust washer:
then the high gear:
then dropped in the shaft:
backside:
rear output bearings...
some paint:
doubler bearings for the 203:
finished up the doubler.
I didnt bolt it together yet because I'm not sure about how I'm going to clock it yet. I need to set the front end up first... this stuff should help with that. :)
gotta figure this out too... it just kisses the link but with more weight on the tire I imagine that'll bubble out on it more:
updated link calc which is pretty close to real world:
bit more progress today with a couple other cruiser heads:
Cut out the plate for boxing the frame
after a lil' trimmin:
tacked:
other side:
tank dropped:
intermission with Mike's bad ass 60 with a turbo 4bt:
cut the holes for the sleeves (rear shackle mount).
some more eye candy...
so finally I got off my rear end a bit (after a little rock band with the family) I spent a little time on the cruiser:
my cut off wheel is soon becoming my favorite tool. I'm committed now.
If you look closely you can see that I got the sleeves welded in and the spring hung. The front perches aren't fully burned in yet.
Got to figure out the fuel cell:
started with doing a bench mockup of the cable shifters:
AND.... its even off the rear jack stands and on its own to rear tires again!!! If you look closely you can see the space from the frame to the jack. :)
Rear shackle angle:
yeah... so it got a little tight in the garage when its sitting on the 42s so I improvised with my hot knife (I had no choice the garage door couldnt go up or down) My wife is going to kill me if she find out before I can get to Home Depot:
Some other shots at ride height which is actually lower than when it was on 39.5s (frame height is about 26inches):
Underneath... pinion angle is about right but I havent burned the axle perches yet.
The front end is pretty much mocked up but I'm waiting for a couple new brackets that'll work better from Ballistic Fab... so until then I'm going to tackle the crossemember:
I got everything tacked up on the 3link to cycle the suspension and check for binding and most important that it all fits. Honestly I think in the end a 4 link up front would have been easier. I plan to mark everything and pull it apart. Then I'll add some scab plates in the necessary spots and fully weld everything up. Anyway pics:
Driver side at almost full droop:
Passenger at full bump with driver almost at full droop:
full bump gets pretty cramped. The harmonic balancer comes about an inch or so of the panhard.
Ram gets close to the pulley but still has a bit of wiggle room:
Passenger at droop:
I ended up with about 5 inches of bump @ 26 inches at the frame. Not too shabby for a full frame'd rig with leafs in the rear. Its actually lower then it was with the 39.5s and SOA (running 42's now).
