For Sale For Sale: 1997 Jeep Wrangler Buggy
bddisi
BDDISI
Cleveland TN
1997 Jeep TJ Buggy $35,000.00
I have title in hand.
All Tube chassis and roll cage 188 and 120 wall x 1.75 DOM
Corp 14bolts front and rear 5.38 ratio on Yukon spools.
Yukon Hardcore Locking Hubs.
Wilwood brake calipers front and rear.
Chromo axles in front with Yukon Super Joints
OEM axles in rear.
Solid inner Cs, Solid Knuckles and Solid hubs in front.
Artec High steer arms.
Corbeau seats
5 point harness
Warn Comp winch, never used.
Optima blue top battery
PSC Hydro Steering, ram, pump and reservoir.
Engine, all aluminum 5.3 cammed with valvespring swap. LS1 intake. Motor had @78,000 miles when installed.
Griffen dual fan radiator.
TH400 tranny with reverse manual valve body, Art Carr/Winters shifter. PTC built.
Derale tranny cooler with electric fan.
205 TC divorced with billet bearing retainers JB twin stick shifter.
Custom Driveshafts .250 wall x2.5 DOM Custom Carrier bearing for two pc driveshafts in front.
15 gallon aluminum fuel cell with rear sump.
Aeromotive fuel pump with pre and post filters.
Aeromotive fuel pressure gage on fuel rail.
Aeromotive electronic fuel pump controller.
LED headlights and tail lights with back up lights and brake lights.
KC LED pods on the pillar
TSL SX 43in tires non sticky on 17in Raceline Beadlocks.
ORI STX struts with res. 14in travel.
4 Hydro bumps
All aluminum control arms and steer arms. 1.25 rod ends upper and lower.
UHMW 3/4in thick skids.
Rear back half of body is 1/8 aluminum.
Viair on board air compressor.
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
