Sold/Expired Ford hp d60 4.88s
joho75287
Denison, TX
Got some stuff that is taking up space and I need to get rid of:
Have 4 saw 2.0s 14" travel.
Springs - 6ea 400lb, 4ea 250lb, 2ea 175lb
One needs a new rod end, which I will order on Monday 8/17 and get it on. 2 could use seal kits which are $22 on eBay for seals for 2 shocks. $750 for all 4 and the extra springs.
Deposit received on coil overs. Still have below items.
Hydro assist setup that came off my YJ with A D60. The steering box is from an astro van so the pitman faces forward so you can use it with a stretched front end. The box is nice and tight and the PSC hydro assist works as it should. I have the mounting brackets, tie Rod, drag link and frame to steering box support as well. The only reason I took it off is that I went to full hydro. $450 for all of it.
Hydro Assist sold.
Still have the 4.88s
Set of 4.88s for a 78/79 HP Ford D60. Good shape. No chips etc. $125
I'm in Denison Tx, will ship on buyers dime, but it won't be cheap based on weight and size of this stuff. I will be at GMP for Dixie run, if that helps anyone, and might be convinced to make a run to Hot Springs (will split fuel cost) if someone over thataway wants anything.
Re: Saw 2.0s, hydro assist ford hp d60 4.88s
Also- willing to trade towards a good TBI 5.7 or a 5.3....
I wish you were closer and id be interested in the hydro assist, but im in GA
What part of GA? I am meeting buddies from GA and FL at Dixie run and one of them might be willing to take it back with them, if you can wait until the end of Sept...
Im in warner robins (middle georgia)
I can bring any of this stuff back to the Dothan AL/ north Florida area from the Dixie Run ride at GMP if that helps anyone.
Re: Hydro assist, ford hp d60 4.88s
Bumpity...
Nobody needs some HP D60 4.88s or Hydro Assist?? :dunno:
Gonna be at Dixie run if anyone wants this stuff but doesn't wanna ship.
Can also drop it off along 40 in AR, Memfrica, and can get it to ATL and deep AL and some of the FL panhandle cause I'll be meeting friends from those areas at GMP....-
Pm's returned.
Believe the whole hydro assist is spoken for... Will update when things finalize.
